CTRL+S
Roman Rodichev
Level 7
Level 7
Hi I've noticed that CTRL+S key combination makes MDS console access unusable until you reboot the switch. Is there a reason behind? Is there a key combination to recover from this condition? Thanks!
Roman Rodichev
Level 7
Level 7
Found an answer through TAC. CTRL+Q can be used to resume output. Very useful! Let's say you are running "fcanalyzer local", CTRL+S can be used to pause output, and CTRL+Q to resume it.
