Upgrading Nexus 5548
GRANT3779
Hi All,
I'm looking to upgrade our Nexus 5548 switches. I can upgrade IOS Routers / Switches no problem but never done a Nexus before.
Currently looks to be running the following -
  kickstart image file is: bootflash:///n5000-uk9-kickstart.5.1.3.N2.1.bin
  kickstart compile time:  3/20/2012 0:00:00 [03/20/2012 07:51:29]
  system image file is:    bootflash:///n5000-uk9.5.1.3.N2.1.bin
  system compile time:     3/20/2012 0:00:00 [03/20/2012 09:00:58]
I'm not sure where to start with this at all. Any pointers and can I upgrade straight to the newest software or do I need to do interim?
Any Pointers welcome.
Bilal Nawaz
Hi Grant.
You will need to download 2 files from Cisco.
System image file
Kickstart image file
Then upload these via ftp or tftp to your Nexus.
Find out the current boot statements by doing "show run | inc boot"
You should see something like this:
boot kickstart bootflash:/n5000-uk9-kickstart.5.1.3.N2.1.bin
boot system bootflash:/n5000-uk9.5.1.3.N2.1.bin
Then you just need to replace these two commands with the new file you uploaded.
no boot kickstart bootflash:/n5000-uk9-kickstart.5.1.3.N2.1.bin
no boot system bootflash:/n5000-uk9.5.1.3.N2.1.bin
boot kickstart bootflash:/NEW..Kickstart.image.bin
boot system bootflash:/NEW.image.bin
Copy run start
then Install command in link below
You can see here: http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5000/sw/command/reference/fund/n5k-fund-cr/n5k-fund_cmds_i.html
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Thanks Bilal,
Can I upgrade straight to newest version from my current one or is there an upgrade path as such to follow?
Hi Grant, you should be able to jump straight to the latest and greatest.
