vfc error disabled because of Ethernet port down?
sokarlsson
We are building a new datacenter and is starting to set up the SAN.
This small DC consist of 2 Nexus 5596UP, a Compellent SAN and 2 Dell M1000e cassis with blade servers.
naive FC part in Nexus has been easy to set up but we have problems with the FCOE setup.
Since the blades are not installed yet none of the Ethernet ports are up. As soon as we bind an ethernet port to a vfc the vfc goes to error disable with this message:
%PORT-2-IF_DOWN_ERROR_DISABLED: %$VSAN 1900%$ Interface vfc101 is down (Error disabled)
Config snippets:
vlan 1900
  fcoe vsan 1900
  name VSAN-A-FCOE
vlan 1901
  name VSAN-B-FCOE
vsan database
  vsan 1900 name "VSAN-A"
  vsan 1901 name "VSAN-B"
interface vfc101
  bind interface Ethernet1/1
  no shutdown
vsan database
  vsan 1900 interface vfc101
  vsan 1900 interface fc2/13
  vsan 1900 interface fc2/14
  vsan 1900 interface fc2/15
  vsan 1900 interface fc2/16
  switchport mode trunk
  spanning-tree port type edge trunk
vlan 1900
  fcoe vsan 1900
  name VSAN-A-FCOE
vlan 1901
  name VSAN-B-FCOE
vsan database
vsan database
interface vfc101
  no shutdown
Do the vfc go error disable because the ethernet interface being down? I was under the impression it should just go "down"
sokarlsson
Forgot. Software release on the Nexus switches are 5.0(3)N2(1)
What you are seeing is normal.. Here are outputs from my lab switch where I shut Eth1/20 which is tied to vFC 20
24.10.5020A.1(config)# int ethernet 1/20
24.10.5020A.1(config-if)# shut
2011 Oct 21 10:16:01 24 %ETHPORT-5-IF_DOWN_CFG_CHANGE: Interface Ethernet1/20 is down(Config change)
2011 Oct 21 10:16:01 24 %FLOGI-5-MSG_PORT_LOGGED_OUT: %$VSAN 100%$ [VSAN 100, Interface vfc20: mode[TF]] Nx Port 21:00:00:c0:dd:12:0e:35 logged OUT.
2011 Oct 21 10:16:01 24 %PORT-5-IF_PORT_QUIESCE_FAILED: Interface vfc20 port quiesce failed due to failure reason: Epp Not Supported by Peer (0x19d)
2011 Oct 21 10:16:01 24 %PORT-5-IF_DOWN_NONE: %$VSAN 100%$ Interface vfc20 is down (None)
2011 Oct 21 10:16:01 24 %PORT-2-IF_DOWN_ERROR_DISABLED: %$VSAN 100%$ Interface vfc20 is down (Error disabled)
2011 Oct 21 10:16:02 24 %ETHPORT-5-IF_DOWN_ADMIN_DOWN: Interface Ethernet1/20 is down (Administratively down)
Thanks a lot. Being used to IOS and that error disable means that one manually have to bring an error disabled port up so I got a bit worried.
