Virtual Machine's from VSphere folder disappeared
JohnFrancis3720
We did some work on the Cluster in Hyperflex through Cisco support and we had to do some updates. The VMs are missing in the folder now which was originally placed in the folder in VSphere 6.5.
Do we have to add it back manually again? or is there a way to get that information and move the VMs to their respective folders based on different types of applications, Domain Controllers, Web servers etc...
Thank you in advance for this
Kirk J
Are you referring to a VM and templates folder you created under the HX cluster level object?
If so, you should be able to move your workload guest VMs back into the folders, or recreate the folders and then move.
Kirk...
