We would like to Add Cisco MDS and Brocade Switch in the same fabric
Sahil_Verma2
We would like to Add Cisco MDS and Brocade Switch in the same fabric.
Please update how we could be able to do so
marcusr
Hi Sahil,
In general terms, we recommend that the Brocade switch is put in NPV mode (Brocade calls this “Brocade Access Gateway” mode), while the MDS switch has NPIV enabled. This would help you avoid potential zone merge failures, zone changes, RSCNs, or Interop Modes, and all the Zoning would be managed in the MDS.
Please refer to the "Cisco MDS 9000 Family Switch-to-Switch Interoperability Configuration Guide" for additional details and specific instructions.
Reference documents:
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/mds9000/interoperability/guide/interopgd/ICG_test.html
https://community.brocade.com/t5/Fibre-Channel-SAN-Technical/Brocade-Access-Gateway-Connectivity-to-Cisco-MDS-Fabrics/ta-p/2209
I hope this helps.
Marcus
Walter Dey
Although there is a interop mode allowing the interconnection, it will create all Kinds of challenges, eg. non matching functionality, tested interoperability on either side, Firmware upgrade that could break any working setup.
Ask the field for references ! I could not give you a single one ?
The advice to set the Brocade in NPV mode connecting to MDS in NPIV mode means totally redesigning the fabric (disruptive).
As a temporary solution: one Brocade fabric and a separate MDS fabric ? Operational cost ??
