Will format bootflash require the switch to go offline
hgibillhgi
I have an MDS9124 that I cannot copy a license file to because it returns "Read-Only Filesystem".  I have been recommended to format bootflash.  I need to know if that action will take the switch offline or reboot it so I can request an outage if necessary.  Thanks for any help you can provide.
Roman Rodichev
Level 7
Level 7
no, formatting bootflash will not take MDS offline (make sure MDS doesn't lose power when bootflash has no image)
you should be able to re-format the bootflash online.
switch# format bootflash:
After the format complete.  Copy kickstart and system image and license back to bootflash:
kenk
Hi All,
Here's the link to the bug details (via our cisco.com Bug Toolkit) which describes the issue and how to
resolve it (via a flash re-format):
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtc62666
Ken
