- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
12-07-2011 08:33 AM
I am working with the Cisco UCS. I have 2x FIC 6120 connected to two Cisco 9124 switches. I have 4 B200 M2 blade servers each with 2x vHBA's assisgned. On the MDS switches I am not able to see the first two blade server HBA's. I issue a sh floggi database command and the physical HBA wwpn on the UCS FIC shows up on one of the ports, but that is it. It should show the physical HBA wwpn and the vHBA's wwpns.
Does anyone have any suggestions on what I can do to get the wwpn's to display? I have shutdown the uplink ports on the FIC and restarted the blade servers and also shutdown the MDS ports. Do I need to clear something on the MDS side ?
Solved! Go to Solution.
- Labels:
Storage Networking
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-07-2011 10:09 AM
Is NPIV enabled on the 9124?
config
feature NPIV
You can log the flogi's in the syslog using the following commands
config
logging level flogi 5
exit
(Reboot the server)
show logging log | i FLOG
David
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-07-2011 11:15 AM
Do you have a SAN boot policy configured in UCS and do you have the SAN WWPNs for each fabric configured in the policy? The servers will not flogi if there isn't a SAN boot policy with WWPNs and boot LUN ID set.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-08-2011 05:07 AM
I don't think you can zone against a WWN but I don't know that for sure. Are those NetApp ports on the same MDS switch?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-07-2011 10:09 AM
config
feature NPIV
config
exit
(Reboot the server)
David
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-07-2011 02:27 PM
Yes it's enabled.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-07-2011 11:15 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-07-2011 02:32 PM
I ended up finding the answer. I was referencing the old wwpn's to the old SAN HBA's in the boot policy, and also had the one to one zoning configured still using the old SAN and the vHBA's for the UCS. Once I removed this out of the policy and rebooted the servers the wwpn's showed up. Thanks for everyone's input.
I have one more question. Can you use the wwnn instead of the wwpn's in the SAN Boot policy for the servers ? My NetApp has two HBA's but the wwnn is the same for both HBA's. Should I create a zone using just the wwnn's for the SAN and then use the vHBA's from the UCS blade servers ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-08-2011 05:07 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-08-2011 05:56 AM
Jeremy is correct, the MDS cannot zone by nwwn.
David
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-08-2011 06:30 AM
OK, thank you. I just wanted to save myself a couple of extra steps on the zoning process. Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-08-2011 06:29 AM
Controller 1's 2x HBA's Connected to MDS-A
Controller 2's 2x HBA's Connected to MDS-B
