Zone Activation / Verification
ihoskins
Added some new zones today, but when I went to do a verification before the activation I got some extra steps....
CHESXIEA2_0_CHNCXLAB02_SPA1[WWN, WWN][Add, Add][Clariion_90602250-SPA1, Emulex_10:00:00:00:c9:91:3d:1a][SC-9222i-D02 fc1/6, SC-9222i-D02 fc1/2]
CHESXIEA2_0_CHNCXLAB02_SPA1[WWN+LUN, WWN+LUN][Remove, Remove][Emulex_10:00:00:00:c9:91:3d:1a, LUN 0x0, Clariion_90602250-SPA1, LUN 0x0][SC-9222i-D02 fc1/2, SC-9222i-D02 fc1/6]
Why would it be removing a zone and then re-adding it?  The only difference is the [WWN, WWN] and the [WWN+LUN, WWN+LUN] type and the LUN 0x0 being removed from the Members...
Thoughts?
maminhas
system displays all changes since last activation , before you activate the zone this time..
this includes your own changes and someone else's change if any since last activation..
e.g if someone else had made changes and not activated the zones, those should be displayed as well.
dynamoxxx
Level 5
Level 5
if you add or remove zone members, it will display it like that.
@dynamoxxx
sammie174
I have had the same experience on both fabrics.  I am continuing to check but so far no other admin seems to have made these changes.  Has anyone else seen this?  Our zones did not have LUN members.
