12-28-2014 02:18 AM
At school I want to start using 802.1x authentication with dynamic Vlan assignment by a Windows Server 2012R2 Radius server.
When a student logs in, I want it to be placed in the "Students" Vlan, when a Administrative employee logs in, I want it to be placed in the "Administative" vlan and when the client is unknown I want to place it in the "Guest" Vlan.
I have several SG200 switches and I configured everything as mentioned in the administrative guide but I cannot get it to work as desired.
What does work:
- If the client is permitted, the switch changes to "authorized" state. (before anyone logs on to the domain with that client)
- When a User logs on that is part of the Administrative employees, the switch changes to "authorized" and when a student logs on, it changes to "unauthorized".
So far so good.
But what doesn't work:
- it does not put the administrative employee in the Vlan "Administrative", it just enables the port on the switch but leaves it in the default vlan 1.
- I can not find the Guest VLAN.
Any help would be appriciated.
Solved! Go to Solution.
01-05-2015 11:10 AM
Hi Wouter,
Yes you are right, 200 series do not support DVA. Only 300 or 500 have this settings at the interface level.
Aleksandra
12-28-2014 11:06 PM
Hi Wouter,
Can you see in the packet capture Radius accept message VLAN attribute? Also please ensure you have the latest firmware and boot code:
http://www.cisco.com/c/en/us/support/switches/sg200-26-26-port-gigabit-smart-switch/model.html#~rdtab1
I would recommend you to open ticket with Small Business team so they can go with you through packet capture and configuration steps:
http://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
Aleksandra
01-05-2015 07:25 AM
Hi Aleksandra
I believe the SG200 series is not able to move users to a radius-predefined VLAN.
It can only enable or disable the port depending on the user/client that logs on to the network.
I tried a SG300-10P and it works with this device. This one also supports guest VLAN's.
Can you confirm this?
01-05-2015 11:10 AM
Hi Wouter,
Aleksandra
