Setting up first CBS250, replacing an SF302 which has gone bad, and not able to get DHCP to pass through VLANs.
I have a Trunk setup on CBS250 Fiber port, on other end is existing SG300. VLANS Untagged and Tagged match on both units. However DHCP passing through the VLANs seems to intermittently working and when it does it takes minutes.
Suggestions, anyone else seen this problem?
I would also like to add, I can't access the CBS250 via its management IP and VLAN from the other side, but can while on an access port of the management VLAN directly connected to the CBS250.
