Cisco Business 350 CBS350-24P-4G
mostafammmm985
device Cisco Business 350 CBS350-24P-4G that I turned on, but the power light is orange and all the ports are not working and I cannot reset it Is there a way to solve this problem?
marce1000
 - Probably not , this looks like a fatal hardware problem , you may try to attach a terminal to the console and check if there are any outputs when power cycled , (for instance)
 M.
