Cisco-gs 300-28 ports
hellow,
I bought 3 switches (gs 300-28 ports)
and i need to connect them to my network, when all the switches are cisco 3560g, with vtp on the vlans.
my question is, how to creat vlans on this switch? and Is it possible to make the gs300 learn the vlans on the 3560g?
if he dosent has the vtp client?
thanks.
rocater
Level 3
Level 3
Hello Yaniv,
Unfortunately the SG300 series does not support VTP. If you are interested in adding vlans, you would have to do it manually. Under 'Vlan Management' you will find all the options to create assign and control vlans. Just remember you will have to have all vlans on a trunk port that links between switches.
