03-06-2018 06:16 AM - edited 03-21-2019 11:22 AM
Hi All
I have a SG350 switch that is the main switch in this network
2 Vlans setup (Voice and Data)
All device are able to get dhcp as normal
The IP Phone as well all get dhcp fine as well
The issue is regarding a Snom M300 Base station that is unable to get ip address on this network at all
Its not exactly the Snom M300 issue as this device get dhcp fine in other networks like my home network
Please can someone point me in the right direction
03-08-2018 04:07 AM
It is not clear where the DHCP server is located but if no obvious errors in the whole setup I would start with packet capture on the switch port connected to the M300 unit and verification what is sent and what is received.
I hope it is a good starting point.
Aleksandra
03-08-2018 04:25 AM
03-08-2018 04:28 AM
no rush at all but worth looking into it, so Yes please :-)
Aleksandra
08-02-2022 02:02 AM
I also have this issue, but now even if I set it statically it doesn't seem to work, but it works in a diffetrent device, the SBS switches are fine and a meraki is fine, seems just to be the SG350.
Grant
