Showing results forĀ
Search instead forĀ
Did you mean:Ā
Cisco SG350 only getting one way voice
Florida850
We have 2 offices, 1 sg350 at each office, phone server at each office and 3 phones at each office. The office can call the other office using the published phone number and have no issues. However when we call via extension- we hear ringback and then when the recipient picks up the call it is just dead air. The recipient can hear the initiating caller but the caller can't hear the recipient. voice vlan is 200 and data is vlan1
Phone server is on Access port 200UT
all other ports are Trunk 1UT, 200T
Martin Aleksandrov
Hi there,
If you have that one-way audio connectivity issue with the phones, the root cause of the problem is not the switches configuration. Instead, you should start looking at the Phone server config.
Martin
