Hi All,
I am observing CRC errors and input errors on one of the Te1/2 interface of WS-C3560X-48 Cisco switch. I have not observed any CRC errors or input errors on the connected interface at other end. Can you please let us know whether the issue is with cable or SFP module.
Effected interface:
TenGigabitEthernet1/2 is up, line protocol is up (connected)
Hardware is Ten Gigabit Ethernet, address is f866.f243.e6b6 (bia f866.f243.e6b6)
Description: *** MAN-SW1B***
MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec,
reliability 254/255, txload 1/255, rxload 1/255
Keepalive not set
Full-duplex, 10Gb/s, link type is auto, media type is SFP-10GBase-SR
input flow-control is off, output flow-control is unsupported
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 3w5d
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 29000 bits/sec, 30 packets/sec
5 minute output rate 45000 bits/sec, 37 packets/sec
68905128 packets input, 8272036576 bytes, 0 no buffer
Received 68904979 broadcasts (68812046 multicasts)
146170 input errors, 130065 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 68812046 multicast, 0 pause input
83524620 packets output, 12642123488 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
Other end.
TenGigabitEthernet1/4 is up, line protocol is up (connected)
Hardware is Ten Gigabit Ethernet Port, address is 503d.e53b.9703 (bia 503d.e53 b.9703)
Description: *** DMZ-SW1B ***
Keepalive set (10 sec)
Full-duplex, 10Gb/s, link type is auto, media type is 10GBase-SR
input flow-control is on, output flow-control is off
Last input 00:00:00, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
5 minute input rate 32000 bits/sec, 27 packets/sec
5 minute output rate 21000 bits/sec, 22 packets/sec
918379921 packets input, 312586470396 bytes, 0 no buffer
Received 881142868 broadcasts (875016400 multicasts)
463132111 packets output, 240865283601 bytes, 0 underruns
