12-24-2014 02:44 PM
I have a problem with Avigilion IP Cameras, they never get IP by the DHCP, but if i connect a pc they get, and wen i connect ip cameras in other routers they get ip, I dont know what the problem is, this is my config log.
switcha2ac8d#
v1.4.0.88 / R800_NIK_1_4_194_194
CLI v1.0
set system mode router
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
ip dhcp server
ip dhcp excluded-address 192.168.1.254 192.168.1.254
ip dhcp pool network demopool
address low 192.168.1.1 high 192.168.1.254 255.255.255.0
lease 7
default-router 192.168.1.254
exit
bonjour interface range vlan 1
hostname switcha2ac8d
interface vlan 1
ip address 192.168.1.254 255.255.255.0
no ip address dhcp
exit
switcha2ac8d#
and i also include a wireshark log
Thanks in advance
12-25-2014 06:12 AM
Hi Jamie,
Thank you for sharing all the information. I cannot see anything wrong in the camera's DHCP discovery messages but then again PC would send different options or boot flags. You may try to compare bootp from PC with camera's one. Either way I guess it would be good idea to report to Cisco Small Business Support team:
http://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
Aleksandra
12-29-2014 01:23 PM
Aleksandra thanks for your response, i will do it.
