Difference SG300-10PP or SG300-10MPP
adaelwireless
Can anybody tell me the difference between these two models ?
The SG300-10MPP supplies 124 watt while the SG300-10PP supplies 62 watt on 8 ports but I'd like to know in which case use one or other ?
Christophe
From the data sheet of the 2700 Aironet:
Power draw
 AP2700: 15W
http://www.cisco.com/c/en/us/products/collateral/wireless/aironet-2700-series-access-point/datasheet-c78-730593.html
Which means that if you are using 8 at the same time you will need 120 watts available
Now from the data sheet of the g300 devices:
SG300-10PP
62W (PoE+ supported)
SG300-10MPP
124W (PoE+ supported)
http://www.cisco.com/c/en/us/products/collateral/switches/small-business-smart-switches/data_sheet_c78-610061.html
You will definitely need a SG300-10MPP to be able to provide enough power.
I hope this was helpful
Please. don't forget to grade the answer or mark it as correct if it was helpful to you so that others can benefit from it.
Don't hesitate to ask any more questions
8 Replies 8
Hi adaelwireless,
The SG300-10MPP stands for Max power over ethernet thus it has more power on the POE side compared to the SG300-10PP. Hope this helps!
I'd like to install 8 Cisco Aironet 2700 access point.
Should I use SG300-10PP or SG300-10MPP?
Power draw
 AP2700: 15W
SG300-10PP
SG300-10MPP
Nice.Thanks for your help.
Christophe
Hi! Have you already purchased the  SG300-10MPP and the 2700 Aironet?  Please refer to cchamorr post for power specifications. Let me know if you have any concerns.
Email me directly at (bsiapco@cisco.com)
Thanks!
cchamorr
Level 5
Level 5
Both switches are PoE Plus capable (802.3at protocol) so the main different is the maximum PoE capacity.
the M on MPP stand for Maximum power which means that all the ports on the switch are capable of providing 15.5 Watts at the same time, while the Sg300-10PP will be able to provide 7.5 watts on every port or go up to 15.5 watts on certain ports but other will not have PoE if you do so.
For example, if you were to use 4 devices that require 15 watts on the SG300-10PP, the switch is capable of doing so, but you will be maxing out the PoE capabilities so, the rest of the ports wont have any PoE left to provide.
Please. don't forget to grade the answer or mark it as correct if it was helpful for you so that other can benefit from it.
adawa
Level 3
Level 3
Hello, adaelwireless.
Ferdinand is correct, the MPP model can provide you max PoE power. How much power would you need?
bsiapco
Hi, adaelwireless.
What are you trying to achieved?
By the way, Ferdinand got it right!
