Differences between SF 300-24P and SF 300-24MP??
pmonardo
Hello all,
First post here, very excited!
On to my question as I cannot seem to find specifics on this.
Besides the MP having support for PoE+, does the 24P have a full 24-port PoE budget or only 12 ports at a time?
What other differences between the two.
I currently have 10 APs plugged into a SF 300-24P and want to add 10 more. PoE consumption is around 3500mW for each AP.
Pasquale
Marvin Rhoads
Generally the product data sheet has this info. For the SF 300  series that can be found here.
It shows that the SF 300-24P supports POE on all 24 ports up to a total load of 180W.
180W/24ports = 7500mW per port. So you should be fine.
Marvin Rhoads
Jon Marshall
edited
I aplogize if I posted in the wrong forum.
First time posting and I didn't notice. Thank you for the responses anyway. it is exactly what I needed
Reza Sharifi
Hi and welcome to the forum.
According to the data sheet, all 24 ports support POE.
have a look at table-1 in this link (under power over Ethernet) section:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps10898/data_sheet_c78-610061.html
Also, here is a link to compare models:
http://www.cisco.com/cisco/web/solutions/small_business/products/routers_switches/300_series_switches/index.html-tab-Models
