02-13-2014 11:20 PM
on an SG300-28 I'm gettng a fatal crash and reset every 24h:
User Name:11-Oct-2013 17:16:30 %CDB-F-CASHINSFAIL: CDBFC_setToRequestedCdb 1: could not insert in cash
***** FATAL ERROR *****
Reporting Task: SNMP.
Software Version: 1.3.5.58 (date 10-Oct-2013 time 17:15:41)
***** DEBUG *****
DEBUG LOG IS EMPTY
0x16adbc
0x166f28
0x6df2b0
0x48fad8
0x4903e8
0x490608
0x4743c0
0x46d844
0x44a87c
0x42046c
0x44d960
0x45bfc0
0x4418e0
0x61cb68
0x1223f0
***************** SYSTEM RESET *****************
Boot1 Checksum Test...............................PASS
Boot2 Checksum Test...............................PASS
Flash Image Validation Test.......................PASS
BOOT Software Version 1.3.5.06 Built 21-Jul-2013 15:12:10
The log is from the serial console and the switch is otherwise idle (however, one port is connected to the LAN).
As the log mentions SNMP, is that situation related to that functionality? Regarding SNMP everything is at the default settings.
Adam
09-29-2014 08:54 AM
I see. Yes, and I'll use the phone then.
Thanks.
09-29-2014 11:38 AM
Seems like a waste of resources for us both to call cisco....can you post your progress here?
I have an SG300-52 if that matters.
09-30-2014 04:26 AM
Hi Jeremy,
Cisco has enough resources for both switches :-)
Aleksandra
09-30-2014 07:45 AM
called support. Seems to be a hardware issue and the switch will be replaced. A new one is already on its way. You'll have to do the same I guess.
11-05-2015 08:33 AM
I had the same problem with 6 different switches of the SG300 series.
After a call with the Cisco support I managed to solve the problem in this way:
- update the firmware
- disable "Auto Configuration Via DHCP" in Administration -> File Management -> DHCP Auto Configuration/Image Update
A.S.
