06-03-2015 02:25 AM
Good day !
The next problem .
Installed Switch Cisco SF200-48P firmware 1.2.9.44.
I try to flash the latest 1.4.1.03.
Immediately error invalid File format.
Although the file with .ros from official site.
I tried and via TFTP and HTTP.
Still I swear on the format of what is wrong ?
Solved! Go to Solution.
06-03-2015 06:40 AM
Hi - if the switch is running 1.2.9.44 firmware you will have to incrementally update the firmware/bootcode on the switch.
https://software.cisco.com/download/release.html?mdfid=283773614&softwareid=282463182&release=1.1.2.0
1. Update to 1.3.5.56 firmware/1.3.5.06 boot code. Boot code has to be done via TFTP.
2. Reboot switch.
3. Update to 1.4.1.03 firmware.
06-03-2015 06:40 AM
2. Reboot switch.
06-06-2015 02:06 AM
HI!
I'll definitely try to do so in the near future and I will post here!
Thank you.
06-15-2015 02:53 AM
Hello!
Thank you very match!
Thats all right.
06-18-2015 12:46 AM
Hey folks,
I believe I'm hitting a similar issue. I have been able to update the boot code to 1.3.5.06 and the Firmware reports as 1.3.0.62. I am unable to update to 1.4.1.03 and presume that I need to make an incremental jump through 1.3.5.56. Unfortunately I can't find this version on the Cisco site.
https://software.cisco.com/download/release.html?mdfid=283771861&softwareid=282463182&release=1.4.1.03&relind=AVAILABLE&rellifecycle=&reltype=latest
Ideas?
Lee
