How do I install a firmware upgrade on a 300 series switch?
hschaffer1948
I have downloaded the ros file, but can't find how to apply it. I know this information must be out there, but can't find it. Thanks
rocater
Level 3
Level 3
Hello Henry,
Once logged into the switch you will want to go to the following location Administration > File Management > Upgrade/Backup Firmware.
From here you will select the file you downloaded and upload it to the switch. Once this process is complete, the firmware will now be located on the switch on image 2.
You will then go to the Active Image tab right below. From here you will change to image 2. Please make sure to save your configuration at this point and then reboot the switch.
rocater
Level 3
Level 3
Hello Henry,
Thanks. That was very helpful.
