01-30-2012 12:14 AM
I need to know how to configure each port in switch SG300-10 to vlans, i need to configure one port "trunk" with catalyst switch and assign 4 ports to different vlans. any solution?!
01-30-2012 05:02 AM
HI Mahmoud Marie,
Please follow the online device emulator to configure the SG 300 Series Switch Vlan Configuration.below is the link
https://supportforums.cisco.com/community/netpro/small-business/onlinedemos?view=overview.
This is the GUI based configuration.Follow the step by step process to configure the VLANs and VTP.This Switch do support inter Vlan Routing to Communicate between VLANS.
Prakash@cil.
01-30-2012 07:52 AM
Mahmoud,
Just wanted to inform you that the SG300 does support 802.1Q vlan tagging but doesn't support Cisco VTP
Hope this helps,
Jasbryan
