06-11-2013 12:06 AM
Hai, greeting.
I had followed the step in Quick Start Guide. I had set a static IP, for example 192.168.1.200 for my computer, but I can't connect to factory default IP address for Cisco SF300-24.
Anyone can help?
Best regard...
ITtrainee
Solved! Go to Solution.
06-11-2013 03:47 AM
Did you check this one from the docs:
When the device is using the factory default IP address of 192.168.1.254, its power
LED flashes continuously. When the device is using a DHCP assigned IP address or
an administrator-configured static IP address, the power LED is on solid.
http://www.cisco.com/en/US/docs/switches/lan/csbms/sf30x_sg30x/administration_guide/78-19308-01.pdf
06-11-2013 03:47 AM
07-08-2013 07:32 PM
Hi, I think the IPV4 Management and Interfaces section in the SF300 Administration Guide would help you.
Cisco Small Business 300 Series Managed Switch Administration Guide
