How to enable telnet or CLI on SLM2024
iankearns
Hi there
Upgrade from previous switch to this gigabit switch at home however I am having issues with the web UI (also posted about that) but would prefer anyway to configure via CLI if possible.
Telnet currently saying connection refused so it looks like it is hitting the switch but not getting anything back so guess port might be closed however cant see anything in the web UI settings to enable it
Any help is appreciated
luis_cordova
Hi @iankearns
The datasheet indicates that the administration is performed only by the web interface:
https://www.manualslib.com/manual/356477/Cisco-Slm2024.html?page=2#manual
@luis_cordova thats a problem as the web UI is throwing back an error and I can only see 12 of the 24 ports available :(
Use REALLY OLDER browser (IE 5 - IE 8) and web UI will work.
