09-09-2015 06:24 AM
Hi All,
I have here a Cisco SG200 - 26P switch..i'm experiencing intermittent ping between VLANs ...host A in vlan 303, host B vlan 319, host C in vlan 319.
intermittent ping from host A to host B
ping ok Host B to host C.
Is there anyway to resolve this problem?
Thanks.
09-09-2015 04:31 PM
sg200s are layer 2 switches , sg300s are the layer3 version so the routing should not be performed by this sg200 switch, the vlans should only be created at layer 2 and then a default gateway should be applied to the switch pointing to the layer 3 device depending on what that is , a router or layer 3 switch
09-09-2015 07:28 PM
Hi Mark,
Yes there is router at back end where the switch is connected....the config works fine on the first week after installation, just recently this problem occurs.
Thanks.
09-10-2015 05:43 AM
what about pings from hosts to his gateway? Perhaps you have a bad cable.
