취소
다음에 대한 결과 표시
다음에 대한 검색
다음을 의미합니까?
VIEWS
답글
IP Helper for SF 302-08P
greggs123
I'm looking for some assistance/guidance for IP helper configuration on a SF 302-08P. Currently, we are connecting a 302 to a Cisco 4507R-E chassis. Our VLANs are correctly configured on each switch (VLAN 1 for data, 2 for voice, 3 for management) and we are able to pass traffic from one switch to the other. Our problem occurs when we are trying to get a DHCP address on a device plugged into the SF 302-08P on VLAN 1, from the DHCP server plugged into the 4507R-E on VLAN 3. Normally we would just use an IP helper address. Unfortunately, we can't seem to find the setting on the 302. Does ip helper exist on the SF 302-08P? Or would we have to use another method?
Thanks in advance
1 응답 1
David Carr
Level 6
Level 6
Hey Network Team,
The option your looking for is the dhcp relay option in the sf302-08p.
Go to the ip configuration tab and select dhcp relay properties and put in the address of the dhcp server.
Next go to the dhcp relay interfaces and select the vlans that will be sending the dhcp request to the server.
