ip http secure-ciphersuite
J_Rega
When I attempt to change the ip http secure-ciphersuite option on a 2960s running IOS 15.2.2-E9 I receive an incomplete command error. If I enter all the options available I receive and unrecognized command error and if I enter "no ip http secure-ciphersuite <enter cipher>" I do not get any errors, but when I "sh run ip http server secure status" the cipher is still listed. I have not been able to find any bug reports or forum posts with this issue. Does anyone know of a fix for this other than buying a new switch that can support an updated IOS?
Just in case you run into this, it's a bug (Bug report) that affects more than the devices listed in the bug report. From the help desk:
"This BUG is not Platform specific
J_Rega
Just ran into the same issue on a 3750X running IOS 15.2.4E9, but it works fine on an IE2000 running the same IOS. I guess I will try to reload the IOS as there is little to no documentation on this issue.
