Is SRW224G4P-K9 full POE?
aozrefanidis
Beginner
Beginner
Hello.
I want to use a managed 24port Switch with poe on all ports simultaneously.
I have found that SRW224G4P-K9 can give up to 180w to any of its ports. My question is if it can give 7,5W to all ports simultaneously or 15W to only 12 ports.
Thank you.
David Hornstein
Rising star
Rising star
Hi Athanasios,
SRW224G4P-K9  allocates POE power according to the power  budget mentioned in the datasheet..
datasheet says the SG300-24P (order p/n SRW224G4P ) has a power budget of  180W
180W / 24 ports = 7.5W per port
But uour answer is both.
SRW224G4P will  "give 7.5W to all ports simultaneously or 15W to only 12 ports"  if that's what you want to do.
There is the newly introduced 500 series switches that will do for example;
order p/n  SG500X-24P-K9 with 24 POE ports  has a POE  power budget of  375W    or   375w / 24ports = 15W per port
regards Dave
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
