Linksys SR2024
greenpagesau
hi,
ive just started at a new company and we have a Linksys SR2024 Switch.
unfortunately no one call tell me what the IP Address of the switch is.
ive done a port scan on our network with no luck.
is there any other way of finding the IP address of the switch?
once i have found the IP - how do i connect to the Web GUI?
6 Replies 6
bbrowncisco
What makes you think the switch has an IP address?
i assume there is some sort of web gui interface for administration - which would need an IP address to connect to.
judging by your reply, i guess there isnt a gui - its just an unmanaged switch?
This switch is umanaged; there is not any gui or IP address.
thanks for your help
cheers
chris
ninhjoatlewis
I believe the sr2024 is a unmanaged switch. No ip address should be assigned to it.
celestius000
Don't listen to these guys, that switch does have a web interface. I know because I have one and can connect to it on the web interface. However I'm stuck there because it also requires a username and password to login and the last IT guy that configured these didn't leave any of that information.
