06-09-2018 04:02 AM - edited 03-21-2019 11:25 AM
hi, in sg500 default all ports in native vlan are trunk. i have configured 2 vlans and set all ports as access. To connect switch with second switch i need one trunk port . Should i change all other ports to access in native vlan ?
Do you create a link aggregation on truk ports ?
Solved! Go to Solution.
06-10-2018 11:26 AM
My name is Iliya Gatsev from Cisco Technical Support Team.
Yes, you change all other ports to access mode in the default VLAN. ( if there is no other special requirement)
You can create LAG from several ports for this uplink connection.Please take a look here:
Link Aggregation Group (LAG) Management and Settings on Sx500 Series Stackable Switches
Please rate this post or marked as answered to help other Cisco customers.
Iliya Gatsev
Cisco STAC Network Engineer
Together we are the human network .:|:.:|:. CISCO
06-10-2018 11:26 AM
Iliya Gatsev
