11-15-2011 12:46 AM
A customer of mine is having serious problems with several ESW-500 switches.
He started a discussion under Netpro, but haven't received any answers. This might be the right group?
He wrote:
I have two new esw-540 switches (one 48 port and one 8 port),
which are making unauthorized cold starts and that gives me a lot problems.
(now it is about three switches)
I added:
My customer needs help with his problem.
Here is some more information:
There are three switches with the samHi
A customer of mine is having serious problems with several ESW-500e problem now, all with the same errormessages from his log
Ciscosw2 ESW-540-48 SN: DNI1452E71E SW Ver. 1.19 Boot Ver.1.0.0.04
Ciscosw3 ESW-540-24 SN: DNI1433E507 SW Ver. 1.19 Boot Ver.1.0.0.04
Ciscosw7 ESW-540-8 SN: CBT15230E9Z SW Ver. 1.1.19 Boot Ver. 1.0.0.07
From ciscosw7:
Nov 11 02:16:03 ciscosw7 %OS-F-MEMORY: OSMEMG_rn_free: Memory magic is invalid
***** FATAL ERROR *****
Reporting Task: BNJR.
Software Version: 2.1.19 (date 14-Jul-2010 time 17:12:34)
0x184e9c
0x182484
0x564110
0x392684
0x395998
0x568630
0x2df10c
0x2df654
0x2e1138
Nov 11 02:17:14 ciscosw7 %INIT-I-Startup: Cold Startup
And he sent me a new errormessage today:
Nov 13 01:38:14 ciscosw5
%SYSLOG-F-OSFATAL:
FATAL ERROR: BNJR: ABORT DATA exception
SW Version : 2.1.19
Version Date: 14-Jul-2010
Version Time: 13:58:28
Instruction 0x2EFB04
Exception vector 0x10#
Program state register
0x20000013
0x002ef7ac
0x002f0390
0x002f08d8
0x002f23bc
0x00134684
Nov 13 01:39:27 ciscosw5 %INIT-I-Startup: Cold Startup
Need urgent advise...
Thank you!
11-15-2011 10:18 AM
Hello!
My name is Robert and I am network engineer for the Cisco SBSC. This is the correct place for the ESW500 series.
From the error messages you are seeing, I would recommend to disable the Bonjour service to see if that helps with the reboots. I am currently looking into the error messages you are getting to see if there is a solution. I would recommend giving us a call as well for immediate assistance on the error messages. Below is a link for our support center numbers.
http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
11-16-2011 05:57 AM
Thank you!
But unfortunately it didn't help.
He disabled Bonjour this morning, and got a new cold start at 14.22CET.
Have you found anything else in the error messages?
11-16-2011 06:28 AM
I am sorry to hear that it did not help. I did find a few cases with the matching error message. The solution on these cases was to update to the latest firmware release. From the look of your error messages, it appears the switches are on the latest (2.1.19).
You can certainly confirm this and even reflash the latest firmware, but if that does not solve the problem, I would suggest you call us to open a case.
11-16-2011 06:34 AM
You are correct, all the switches have the latest firmware as far as I know.
I will have to have my customer call you to open a case. Should he refer to this discussion?
Thank you so far.
11-16-2011 06:38 AM
Yes, when you or your customer contacts us, have them reference this post.
11-16-2011 06:40 AM
Ok, thats fine.
And thank you again fort quick replays!
01-09-2012 05:21 AM
For your information.
My customer now have used firmware version 2.1.16 (instead of the newest version 2.1.19).
No coldstarts since end of november.
So it seems that firmware 2.1.19 is faulty...
