Hi folks
I use the SLM2024 in the office at home and finally I decide to seek if I can do something about the fan noise from the unit.
Otherwise the switch is perfectly fine.
Can I ask please;
1) - Can I swap out the stock fans for quieter ones? (Anyone do this?)
2) - Does it pose a risk if I disconnect the fan power?
3) - Any other options to reduce the noise? Any IOS command which can spin-down the fans...etc?
James.
