Packets per second (PPS) Cisco SG500-52MP 52-port Gigabit Max PoE+
donmatlock1
This year we deployed over a hundred Chromebooks in one area of our school for the Gr 7's (1:1 ratio).  Yesterday I found that the Meraki MR32's in that area (I have 3 of them dedicated for that area of the school) were laggy in terms of authenticating students (radius auth).  I had roughly 40-50 kids per access point...so it was quite a good test/heavy load.  To be preventative and minimize any stress on the AP's in the future, I have increased the bit rate to eliminate A and B wireless protocol devices, in doing this the AP doesn't have to work hard on a low bit rate item and it kind of draws a line in the sand for the next AP to pick up the client.
Ok, now that I have done that, I was also curious about my switch, I did the command #show cpu input rate and found it was bouncing between 75 and 100, I attempted to find the specs on this switch that would show how many packets per second (pps) it can process, but could not find any info in the whitepapers I came across.
Is anyone able to shed some light on this, as I want to ensure the switch itself is up to the task of all those devices at once.
Thank you,
Don
Jorge Obregon
I hope this will be useful fir you.
Feature
Description
Performance
Switching capacity and forwarding rate
All switches are wire-speed and non-blocking.
Product Name
Capacity in mpps (64-byte packets)
Switching Capacity (Gbps)
SF500-24
9.52
28.8
SF500-24P
9.52
28.8
SF500-24MP
9.52
28.8
SF500-48
13.10
33.6
SF500-48P
13.10
33.6
SF500-48MP
13.10
33.6
SG500-28
41.67
72
SG500-28P
41.67
72
SG500-28MPP
41.67
72
SG500-52
77.38
120
SG500-52P
77.38
120
SG500-52MP
77.38
120
SG500X-24
95.24
128
SG500X-24P
95.24
128
SG500X-24MPP
95.24
128
SG500X-48
130.95
176
SG500X-48P
130.95
176
SG500X-48MP
130.95
176
SG500XG-8F8T
238.1
320
regards
Thank you,
Is there a quick calculator to change pps into mpps...Looked around on Google with no results for a conversion calculator or chart.
well Mpps stands for Millions of Packets Per Second. basically the same as PPS but 10^6. I hope this is what you are refering.
regards,
