03-19-2016 02:24 PM
How do I point a vlan interface to a dhcp server on SG500? On a 6500, I use "ip helper-address". Trying to use the same command, however, the switch complains about "% missing mandatory parameter". Can you please advise me?
Thank you so much!
03-21-2016 07:51 AM
From memory, I think you need to use the DHCP Relay function on the SG switches:
#ip dhcp relay address x.x.x.x#ip dhcp relay enable#int vlan yyy#ip dhcp relay enable
Log in to Community
