Problem with Link Aggregation with an SG 200-26
mcmatt1111
Hello, I'm trying to setup Link Aggregation on this switch for an HP server with a 4-port NIC which is teamed.  I create the LAG and see in the HP Network Utility where each port in the team disconnects then reconnects and the server has internet access, but workstations cannot access the server (can't browse UNC, RDP, ping, etc.) and vice versa.  This is the only switch at the site, all the workstations are plugged into it.  Rebooting the switch after creating the group didn't have any effect.
rocater
Level 3
Level 3
Hello Matt,
The SG200 LAG supports LACP as the link protocol. In order to ensure that the link will work, the teaming will also have to support this.
Another important note about LAG on this switch is that it does not use round robin for load balancing.
