Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
Labels
Update: This portion of the project has finished earlier than initial projections. We are approaching our latest step in relabelling posts across the Small Business board. 1 week from today, read-only mode will be active on this discussion board fro...
CoreyP319 by Cisco Employee
  • 1262 Views
  • 0 replies
  • 1 Helpful votes
Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Installation Guide - Catalyst 1300Hardware Installation Guide - Catalyst 12...
  • 5971 Views
  • 4 replies
  • 17 Helpful votes
Hi,I'm  setting up an SG-300 and would like to block some traffic with ACLs.  While I'm  new to cisco products, I was able to easily setup an IP based ACL to restrict  certain IPs from accessing specific ports, but my problem is with applying these ...
I'm trying to get a 300 Series 8 port switch to trunk to my 1140 Access Points.  I"ve added two VLAN's to the AP's and I believe I have them setup properly, I"m having trouble with understanding the gui config on the switch, and how to setup VLAN's a...
Hi,does someone knows if the small business switch SD2008  10/100/1000does handle jumbo frames and up to which length ?I've purchased the switch March 2010I could not find this information on this forum or any product information / data sheetthere is...
rolandwe by Level 1
  • 1528 Views
  • 2 replies
Greetings,We have two SG 300-52's and one SG 300-28 on our network. These are connected together via fiber optic gBic cards.One gBic card in SW1, Two gBic cards in SW2, and one gBic card in SW3.Nothing has been configured except for the managmanet IP...
I've looked at the demo manual (Demo script nijkola 300-series v6 ) to configure two different ports on two different VLAN and make them availables, but I can't get it work.I kindly ask how static routes work, because I got the same config as in the ...
Hello,Anyone else have problems with OS X and the SG200-26 switch?I've connected two different macs to it and tried to load the default url.  Nothing loads and it time out.I've had this switch working before, but I've had to plug the macs into a 4 po...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
