I have a understanding problem with my ACL for contacting a DHCP server.
Here are my used Server:
1. Fritzbox with DHCP server (IP: 192.168.100.65/27
2. CBS250 VLAN-1 (IP: 192.168.100.66/27)
3. Clients with Port-Range (192.168.100.70 - 192.168.100.80/27)
First problem:
Clients must contact the Fritzbox to get there IP from the Fritzbox DHCP server. My Input ACL looks like:
permit udp any any 192.168.100.65 0.0.0.0 67-68 ace-priority 1
Looks for me okey, but the client is unable to get an IP from the DHCP server. When I change the wildcard from the IP 192.168.100.65 0.0.0.0 into 255.255.255.255 it will works fine. I don´t understand why
Second problem is, if I put more than 4 ACE into an ACL, I got the Message:
Cannot apply - TCP/UDP port range egress amount exceeded
My Clients Port-Range (192.168.100.70 - 192.168.100.80/27) is fix. Question is, there are some more device in the subnetz, how can I limit an ACE for exactly this port-range?
