07-22-2011 09:10 AM
I have SG200 50/50 Port Switch and the devices that connect into it are servers and workstations
Few days and until we experience network dropouts and when take a look at the switch log it gives me this?
2147483423 2011-Jul-22 16:34:53 Informational %LINK-I-Up: gi3, aggregated (1)
2147483424 2011-Jul-22 16:34:53 Warning %STP-W-PORTSTATUS: gi3: STP status Forwarding, aggregated (1)
2147483425 2011-Jul-22 16:34:50 Warning %LINK-W-Down: gi3, aggregated (1)
2147483426 2011-Jul-22 16:34:37 Informational %LINK-I-Up: gi3
2147483427 2011-Jul-22 16:34:37 Warning %STP-W-PORTSTATUS: gi3: STP status Forwarding
2147483428 2011-Jul-22 16:34:27 Warning %LINK-W-Down: gi3
Device connected to gi3 is a Web Server
This is also happening on more ports ie 20-printer, 13-Cisco Wireless Access Point, 24 File Server etc
which I don't know what is going on. With my research, it said something about
spanning protocol. Is this possible to disabled?
The other cisco switch where desktop are also connected doesn't have this error.
My firmware is 1.1.0.73
Boot Version 1.0.0.1
Any ideas will highly be appreciated.
AC
06-04-2012 04:29 PM
I have started seeing this problem as well on my SG200-50 recently. It seems to happen when the switch is under a more than normal load (transferring a large file, etc.). Usually a reboot of the switch makes the problem go away for a month or so but it keeps coming back and is getting annoying.
06-06-2012 02:40 AM
Hi Derek,
My post was year old but to give you some idea, I disabled the STP if you are not using it really.
Now, I get these logs as well but only when a particular device was switch OFF & ON.
Also, rebooting the switch helps performance specially when it is running for quite a long time.
Hope this helps.
AC
