03-12-2017 03:55 AM
i have one cisco switch 350 XG and 6 switches SF 300 and i created Vlan for each swith and than all this switches connect to switch 350 XG
i already created Vlan interface for each Vlan. and elso enable IP routing on the mulitlayer switch .
but there is no routing between the Vlans.i don,t know why?
here is the configuration for the multilayer swicth
switchecabc7#sh run
config-file-header
switchecabc7
v2.0.0.73 / RTESLA2.0_800_094_004
CLI v1.0
set system
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
spanning-tree priority 4096
vlan database
vlan 9-10
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
bonjour interface range oob
hostname switchecabc7
no passwords complexity enable
username cisco password encrypted cb681d96635d9d1b8715d4d41d30d5046f7f64ad privilege 15
ip ssh server
snmp-server server
ip telnet server
interface vlan 9
ip address 192.168.9.1 255.255.255.0
interface vlan 10
ip address 192.168.10.1 255.255.255.0
interface tengigabitethernet1/0/3
no switchport
interface tengigabitethernet1/0/9
speed 1000
spanning-tree link-type point-to-point
switchport mode trunk
macro description switch
!next command is internal.
macro auto smartport dynamic_type switch
interface tengigabitethernet1/0/10
speed 1000
03-12-2017 09:41 PM
You are trunking to the downstream switches. Each of those downstream switches will need their access ports put into the respective VLAN.
