SF220 how to remove double login prompt through SSH
PremNaresh2556
SF220 how to remove double login prompt through SSH. its giving issues when trying have NCM in Solarwinds.
5 Replies 5
marce1000
 https://community.cisco.com/t5/small-business-switches/sg300-10-on-1-3-7-18-firmware-has-double-login-on-ssh/td-p/2516109
 M.
Thank you for the reply, but that solution is working for sg300 but not for SF220.
 - Can you provide some 'trail' or screenshots on the manifestation of the double login prompt sequence ?
 M.
please find the pic.
ajpareek
First of all i recommend to download the firmware from Cisco URL and upgrade the firmware version on the device.
Please run the below command on switch :
conf t
ip ssh password-auth
and see if it working or not.
It should work in latest firmware version; if it is not running so probably due to lower end model, the command is not available.
Ajay Pareek
