We are attempting to connect to trunk a 302-8PP switch to a 2960x and having difficulties in getting access to the web UI from outside of the local 302 switch ports. The 302 passes traffic on vlan 24 but we cannot Ping or access the Web UI of the 302 from our internal network. We can access other switches that are on vlan 5 and the same subnet. Are there remote management settings that we may be missing in the 302? And by remote we are not referring to NAT and port forwarding just internal LAN access from different subnets.
Any assistance on this issue would be greatly appreciated!
UPSTREAM SWITCH (2960x)
interface FastEthernet0/7
switchport trunk native vlan 5
switchport trunk allowed vlan 5,17,24
switchport mode trunk
srr-queue bandwidth share 10 10 60 20
queue-set 2
priority-queue out
mls qos trust cos
auto qos voip cisco-phone
spanning-tree portfast
302-08PP
config-file-header
SF302-08PP
v1.4.7.6 / R800_NIK_1_4_194_194
CLI v1.0
set system mode switch
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
vlan database
default-vlan vlan 5
exit
vlan database
vlan 5,17,24
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
hostname SF302-08PP
management access-list all
permit
exit
management access-class all
interface vlan 5
name Mgmt
ip address 10.5.0.63 255.255.255.0
no ip address dhcp
interface vlan 17
name A
interface vlan 24
name B
interface fastethernet1
switchport mode access
switchport access vlan 5
interface fastethernet2
switchport access vlan 24
interface gigabitethernet1
switchport trunk allowed vlan add 17,24
exit
ip default-gateway 10.5.0.1
