SG-300-20 Port based address setting
sangjun park
We are using the sg300-20 switch
A each static ip address should be assigned to each port . Can it be set up?
ex. port 1 is static ip address 10.0.0.1
10.0.0.1 is set on the device even if other devices are connected.
Seb Rupik
Hi there,
The SG300 does support routed switchports. First you need to put the SG300 in router mode:
set system mode router
Once rebooted, you can configure an IP subnet on each interface:
int gi1
  ip address 10.10.1.254 /24
int gi2
  ip address 10.10.2.254 /24
int gi3
  ip address 10.10.3..254 /24
cheers,
Seb.
