SG-300 28Port Gigabit Switch
Priyank Shah
Hi All,
Does the SG-300 switch support Multicast VLAN routing ?
Can I have a IPTV Vlan and distribute the feed to 10 different Vlans ?
I have tested the multicast-tv vlan feature but it sends all the multicast groups to the client port in which we tag the tv-vlan. Is it possible to use the multicast-tv vlan feature so that it only sends the requested multicast group to the client port ?
According to the datasheet
IGMP Querier - IGMP querier is used to support a Layer 2 multicast domain of snooping switches in the absence of a multicast router
Does this mean that multicast routing is not possible ?
cristgon
Hello Priyank,
Thank you for using the Cisco Small Business forums. My name is Cristian, I am an eContent developer and I am part of the Small Business Support Community. The datasheet also mentions Multicast TV VLAN that might better suite your needs:
Multicast TV VLAN
Multicast TV VLAN allows the single multicast VLAN to be shared in the network while subscribers remain in separate VLANs (Also known as MVR)
I also found some articles from out knowledge base that might be of some assistance:
I hope you will find this answer useful, and I hope you reply back with any questions or concerns.
*Please mark the question as Answered or rate it so other users can benefit from it*
Cristian Gonzalez
Cisco eContent Developer
