11-23-2016 08:41 AM
I have a 24 SG 300 POE. On port 22,23 and 24 I have connected access points. The ports are configured trunk with VLAN 400 native and and vlan 300. Trying to create VLAN 400 employee-wireless and 300 for Guest. The issue is the AP are not getting IP address on the DHCP request. The router is the DHCP server. The port on the router is configured for trunk with sub-interface,VLAN 1 native, vlan 300 and vlan 400. On the swith port gig3 is trunk and it passes vlan 1,300,400. Can you tell me what I am doing wrong.
Jose Luis
11-23-2016 11:58 PM
what AP vendor/models are you using? Is that solution with wireless controller or standalone APs?
11-25-2016 02:56 AM
The AP are Motorola with a controller.
11-25-2016 08:56 AM
you know, there is no evident problem within your description, so I would like to see how that APs are working.. what exact models they are?
