SG 550x VLAN Issue
Dav1787
Hi Guys
this is driving me crazy as its makes no sense to me.
2 x cisco 550x switches set to stand alone mode. Connected via ethernet both on ports 25.
S1 L3sg 550,
S2 L2
native vlan set to vlan 100.
second create -  vlan 20
static route added for vlan 20 192.168.20.1. S1 cant ping svi with a response
S2 cannot ping 192.168.20.1 by default. If i add vlan 20 untagged on SW1 port 25 S2 can ping 192.168.20.1???
S2 has not had vlan 20 tagged on port 25! Devices plugged into S2 on vlan 20 cannot ping 192.168.20.1 but the switch can.
devices still cannot ping 192.168.20.1 if i tag vlan 20 on port 25.
it appears vlan 20 traffic on S2 is carried over on the native vlan by default and i have no idea why.
5 Replies 5
marce1000
 - Disable all instances of auto-smartport and check if that can help , e.g. :
      switchxxxxxx(config)# interface range gi1/1/1-20   -> change according to your needs
      switchxxxxxx(config)# no macro auto smartport
 M.
Thank you. I always disable smartport as soon as i set them up
Dav1787
L3 Switch
config-file-header
switchc9d707
v1.4.11.4 / R800_NIK_1_4_219_025
CLI v1.0
set system mode router queues-mode 4
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
vlan database
default-vlan vlan 100
exit
vlan database
vlan 1,20
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
bonjour interface range vlan 1
hostname switchc9d707
username admin password encrypted 78c87b0ed4de64f81776a289f8ccefe1d477ee01 privilege 15
ip ssh server
interface vlan 20
name cctv
ip address 192.168.20.1 255.255.255.0
interface vlan 100
name Network
interface gigabitethernet1/1
interface gigabitethernet1/2
interface gigabitethernet1/3
interface gigabitethernet1/4
interface gigabitethernet1/5
interface gigabitethernet1/6
interface gigabitethernet1/7
interface gigabitethernet1/8
interface gigabitethernet1/9
interface gigabitethernet1/10
interface gigabitethernet1/11
interface gigabitethernet1/12
interface gigabitethernet1/13
interface gigabitethernet1/14
interface gigabitethernet1/15
interface gigabitethernet1/16
interface gigabitethernet1/17
interface gigabitethernet1/18
interface gigabitethernet1/19
interface gigabitethernet1/20
interface gigabitethernet1/21
interface gigabitethernet1/22
interface gigabitethernet1/23
interface gigabitethernet1/24
interface gigabitethernet1/25
switchport trunk allowed vlan add 20
interface gigabitethernet1/26
interface gigabitethernet1/27
interface gigabitethernet1/28
exit
macro auto disabled
no macro auto processing cdp
no macro auto processing lldp
macro auto processing type ip_phone disabled
macro auto processing type ip_phone_desktop disabled
macro auto processing type switch disabled
macro auto processing type ap disabled
Dav1787
L2 Switch
config-file-header
switchc320c9
CLI v1.0
set system mode switch queues-mode 4
ssd-control-start
ssd config
vlan database
exit
vlan database
vlan 1,20
exit
hostname switchc320c9
ip ssh server
interface vlan 100
ip address 192.168.1.2 255.255.255.0
no ip address dhcp
switchport mode access
switchport access vlan 20
[A no macro auto smartport
switchc320c9#sh run
config-file-header
switchc320c9
CLI v1.0
ssd-control-start
ssd config
vlan database
exit
vlan database
vlan 1,20
exit
ip ssh server
interface vlan 100
no ip address dhcp
exit
macro auto disabled
ip default-gateway 192.168.1.1
Dav1787
please can anyone help
