SG200-08 VLAN Set Up
Burbank9
Network equipment: Edgerouter and SG200-08 L2 switch.
The IP assignment, VLANs logic and firewall set up are done by the Edgerouter.
I am trying to assign different ports on SG200 to the 2 VLANs (VLAN_10 and VLAN_20). See the following pics for the membership set up. For some strange reasons, the ports (G2-G5) assigned to VLAN_20 are working but not the ports (G6,G7) assigned to VLAN_10. Would really appreciate any insights. Thanks in advance
Burbank9
See attached pics for the SG200 set up.
Ruben Cocheno
@Burbank9
Try to remove Membership from VLAN 10 on those ports assigned to G6, and G7. Also i suspect the routing is done at the Edge Router, so you must have a trunk interface with both VLANs tagged ideally from that switch to the Edge Router, unless you have a dedicated interface on the Edge Router attached to each VLAN on the switch, and in this case you can either use trunk on access mode.
Each VLAN is configured with a unique VLAN ID (VID) with a value from 1 to 4094. A port on a device in a bridged network is a member of a VLAN if it can send data to and receive data from the VLAN. A port is an untagged member of a VLAN if all packets destined for that port into the VLAN have no VLAN tag. A port is a tagged member of a VLAN if all packets destined for that port into the VLAN have a VLAN tag. A port can be a member of only one untagged VLAN but can be a member of multiple tagged VLANs. A port in VLAN Access mode can be part of only one VLAN. If it is in General or Trunk mode, the port can be part of one or more VLANs. VLANs address security and scalability issues. Traffic from a VLAN stays within the VLAN, and terminates at devices in the VLAN. It also eases network configuration by logically connecting devices without physically relocating those devices.
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
Yes, routing is at the Edge Router (ER) level and there is a trunk interface between ER and the switch.
Port G1 in the switch is the trunk link to ER.
For VLAN 10 set up, I believe port G1 should be a Member and Tagged (of VLAN 10). Port G6 and G7 are also Member and Tagged (of VLAN 10). Other ports (G2 to G5) are not members of VLAN 10. In this case ports G6 and G7 are set up to receive tagged information from ER and vice versa.
Similarly for VLAN 20, port G1 is also a Member and Tagged (of VLAN 20). Port G2 to G5 are also Member and Tagged (of VLAN 20). Other ports (G6 and G7) are not members of VLAN 20.
This is not working and I am wondering why. Thanks.
