SG200-18: backing up config not working properly
Timo Kokkonen
PID VID:        SLM2016T V01
Firmware Version:       1.0.0.19
Is this known bug that you cannot backup (export) full running or startup config from this switch?  Will this be fixed in next firmware? (btw, still no new firmware with CDP support for this script altough sales literature mentions that it should have already been available...)
Switch does let you backup configuration as text file (which looks similar to normal IOS config syntax), but it doesn't contain all settings so the file is pretty much useless to restoring the config to another switch.
At least following settings are missing from the file:
     - management interface config (including DNS settings)
     - passwords
     - remote syslog server config
     - SNTP server config
     - IGMP config
     - LLDP config
Below is a sample config which clearly is missing lot of stuff:
spanning-tree priority 4096
interface ethernet g1
description "switch1"
exit
interface ethernet g2
description "switch2"
exit
interface ethernet g3
description "server1"
exit
interface ethernet g9
description "switch3"
exit
interface ethernet g10
description "PC"
exit
interface ethernet g17
description "router1"
exit
interface ethernet g18
description "router2"
exit
interface range ethernet g(1,9)
flowcontrol auto
exit
port jumbo-frame
bridge multicast filtering
switchport default-vlan tagged
exit
switchport mode general
exit
interface range ethernet g(2-8,10-18)
switchport mode access
exit
vlan database
vlan 100
exit
interface range ethernet g(10-16,18)
switchport access vlan 100
exit
switchport general allowed vlan add 100
exit
interface vlan 100
name data
exit
switchport general acceptable-frame-type tagged-only
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
David Carr
Level 6
Level 6
Timo,
Yeah, I agree with you that the settings you have configured should be displayed on the output of the config.
If you already have that is fine, please call into the SBSC at 866-606-1866 and let a support engineer troubleshoot and document what is happening.  Then they can test the settings and see if they replicate the same issue.
If so, then we can go forward with getting this issue resolved.
Thank you
I opened ticket yesterday and heard that the're been similar issues where setting "special" characters in VLAN names can cause export(backup) of the config fail on older Smart Switches. That got me thinking that this must be caused by some particular configuration setting I had made.
I rebooted the switch into factory settings and started configuring it step by step, while testing the export (or backup as the GUI calls it) of the configuration after each step. I found out that after changing "Interface VLAN Mode" for any port from the default "Trunk" to "General" (and apparently even setting it to "Access" triggers same bug), export of the configuration starts failing.
Kicker is, that there appears to be no way to recover from that state, setting the port/interface back to Trunk won't help, only way to "recover" seems to reboot to factory defaults and reconfigure (and just not ever change "Interface VLAN Mode" for any port).
Steps to replicate the problem on a SG1800-2  (fw 1.0.0.19):
  1. reboot switch to factory settings
  2. create VLAN 100 "data"  (this step probably can be omitted)
  3. configure VLAN settings for port g1:
          [VLAN management -> Interface Settings -> g1 (edit)]
          - Interface VLAN Mode: General
          - Administrative PVID: 1 (default)
          - Frame Type: Admit Tagged Only
          - Ingress filtering: Ednable (default)
          - Auto Voice VLAN Membership: disable (default)
          - Voice VLAN QoS Mode: Telephony source MAC Address (default)
If you export switch config before configuring interface g1 VLAN mode, you should see somethign like:
vlan database
vlan 100
exit
interface vlan 100
name data
exit
bonjour service enable csco-sb
bonjour service enable http
hostname switch0
no passwords complexity enable
username cisco password e15d5b7c1818860e2c2a9de7dab6654c0f01da2c level 15 encrypted
But after changing port g1 VLAN settings export (backup) of config is broken:
exit
vlan database
vlan 100
exit
interface vlan 100
name data
exit
exit
