SG200-26P not powering three access points.
minitrucker007
I just purchased a Cisco SG200-26P to power three Ubiquiti UAP-LR-3 UniFi AP that are going in a new small network. I added the three AP’s to port 1, 2, and 3 and they are not powering up off the POE switch. I got into the switch and I don’t see anything that stands out for them to not power up. The AP’s work powered up with POE injectors.
Minitrucker007
minitrucker007
It looks like the AP's are 24Volt and the switch is 48V. Is there a way to turn down the Voltage on the port?
Hi Minitrucker,
SG200-26P is 802.3af compliant but from what I manage to read Ubiquiti UAP-LR is not 802.3af/at compliant, correct me if I am wrong as I did not really find the datasheet for your specific AP.  This would mean that the AP would need the injector or specific switch rather than any. As it uses non standard PoE.
Aleksandra
Your right there not. I am going to send these UAP-LR AP's back and upgrade them to the big brothers. Thanks for the help.
