Showing results forĀ
Search instead forĀ
Did you mean:Ā
SG220-50 Memory issue
Ale_info
Hi there.
I have a problem with one of my cisco switches and i have no idea if there is a solution or not, but i can't find any.
Switch is not saving any config, always return to an old mirror-config. I tried it by web interface, console  (ssh), console (serial), etc. I tried to reset to factory defaults without success, including pressing physical reset button. Update firmware isn't possible, firmware upload complete but not appears on image-2 file.
I guess it can to be the flash memory, but i'm not sure.
When i write, after a config, console shows this:
Building configuration...
Node totlen on flash (0xffffffff) != totlen from node ref (0x0000049c)
Node totlen on flash (0xffffffff) != totlen from node ref (0x000001cc)
Node totlen on flash (0xffffffff) != totlen from node ref (0x00000044)
Node CRC ffffffff != calculated CRC f09e7845 for node at 001f4cb4
Node CRC ffffffff != calculated CRC f09e7845 for node at 001f5150
Node totlen on flash (0xffffffff) != totlen from node ref (0x00000030)
Node totlen on flash (0xffffffff) != totlen from node ref (0x00000048)
[OK]
Anyone can help?
Thank you so much.
marce1000
  - This looks like a hardware error on the flash - replace this device (RMA).
 M.
