SG220 double login
Jernej.Sinic
I have problems with double login on Cisco SMB SG220 (IOS version 1.1.4.1 ). There is no option to enable Automatic login in GUI (no option in GUI Security > SSH Server > SSH User Authentication and tick Enable for SSH User Authentication by Password)
On CLI there is no command ip-ssh password-auth.
Could someone help with this issue?
mdangeles6
UP!
I'm also having this issue and looking for a fix.
Jitendra Kumar
Hi there,
My name is Nikola and I'm a Cisco Small Business Devices Team member.
I recommend you to download the firmware from Cisco URL and upgrade the firmware version on the device.
Then try the below command on switch :
conf t
ip ssh password-auth
It should work in latest firmware version; if it is not running so probably due to lower end model, the command is not available.
